Rod Elliott (private email) said:Matthew,
Attempting to use the same battery for phantom and to power the preamp is a really bad idea, for a multiplicity of reasons.
First and foremost, the input XLR, mic body, etc. will be at a negative voltage referred to earth/ground. Should the mic or connector contact the chassis of the recorder you'll have a partial short on the battery. Exactly what will happen is unknown, but it won't be good.
Your circuit compromises the effectiveness of the ground connection - it is meant (and expected) that ground really does mean ground!
For the sake of an extra battery you'll end up with a circuit that will cause you grief at some stage.
Cheers, Rod
For the IC to function in this particular circuit pin 4 (Vcc-) must be at the battery ground, pin 8 must be at the battery V+, (Vcc+) and the input must be biased 1/2 way between those points.The output of the IC is, according to the datasheet, pin 6, so that's okay. Pin 4 is Vcc-, which is the ground for the IC, right? Because that would mean the the output ground should be (and is, in our diagram) 0v (-ve). If the output ground was meant to be the 'virtual ground' of the preamp, the output ground would effectively be pin 3 of the IC, which according to the data sheet is IN+, and that doesn't make sense to me.
I also wonder what he means by the effectiveness of the ground being compromised. The only change really is that the mic's ground isn't the same as the pre's ground, but it shouldn't matter because they're not connected (unless that's exactly what he means about it being compromised). The only other thing would be that the output ground is -ve, but as I mentioned previously, that seems correct for the IC's output. Quite confusing!
Vcc+ goes to 22V and Vcc- goes to 0V exactly as in the most recent schematic.The output of the IC is, according to the datasheet, pin 6, so that's okay. Pin 4 is Vcc-, which is the ground for the IC, right? Because that would mean the the output ground should be (and is, in our diagram) 0v (-ve). If the output ground was meant to be the 'virtual ground' of the preamp, the output ground would effectively be pin 3 of the IC, which according to the data sheet is IN+, and that doesn't make sense to me.
It doesn´t reall matter whether the virtual ground is buffered or not. The main point is that the mic ground + shield needs to be connected to the -V supply, so you´d then want to have the box and the output ground connected to the same potential.I think the original reason it was suggested was because you were going to use a resistive rail splitter so 0V would provide the best path back to the battery. If you're using a direct (not virtual) ground midpoint (your ground wire directly touches the batteries) you may use either. I don't think it matters as long as an output cap is present. The output circuit won't present the issue that Rod Elliot mentioned because that circuit will not be sharing a power supply, only a single ground reference connection.
Yep, I think you fit right in here.It's going to be fixed inside a case, so "" (shorts, tehe) should be unlikely anyway.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
