Pre filter and dissipation issues for an 8 amp regulator
coinmaster
Joined Dec 24, 2015
502
I'm building a -30v series regulator which will be used to power 4 2 amp current sources but I have come across some practical issues.
For starters I cannot figure out a way to pre filter the AC going into the regulator because I cannot find any lytic caps that can handle the ripple current. I either get large caps which sink huge ripple currents or I get small caps and use a big RC resistor which drops the voltage to nothing with amps of current. There are no cheap inductors that will work and even if they did I would have to use large caps anyway.
I also have a question about heat dissipation. The entire setup will dissipate about 936W across 18 mosfets, 24 if I decide to go with separate regulators per current source.
I currently have a 12 inch by 12 inch alluminum heatsink that has thick 1.3 inch deep fins throughout the surface area on one side. I purchased it here http://www.heatsinkusa.com/12-000-wide-extruded-aluminum-heatsink/
How much heat can I expect this thing to dissipate?
coinmaster
Joined Dec 24, 2015
502
Let's assume I went with a crc filter with 10,000uf caps and a 10 ohm resistor. The first cap would take in about 30 amps ripple current.
Sadly That's about as far as it goes for capacitor size because any less and the resistor wattage and voltage drop will be too intense and higher capacitance will draw even more ripple current.. So you see my issue. Unless LTspice is lying to me that is.
Papabravo
Joined Feb 24, 2006
21,225
No -- I don't see your issue at all. I guess you'll just have to explain in greater detail.
Sensacell
Joined Jun 19, 2012
3,451
I think part of the problem is your concept of 'filtering' in a DC power supply, there is no need for any series resistors, don't use them.
Look at any basic schematic for a linear power supply, there are never resistor in series with the filter caps, except perhaps themistors, to limit inrush current.
The DC from the rectifiers directly feeds large capacitors, don't think of this as an RC filter, but as an energy reservoir.
The job of the regulator is to compensate for the 100/120 Hz ripple on the reservoir caps.
As for heat sinks, look for the C/W rating of the heatsink, that's the degrees C per watt.
At 900 watts, you should consider forced air cooling, this method can increase your safe dissipation dramatically.
coinmaster
Joined Dec 24, 2015
502
I tried using an LC filter instead of a CL filter in LTspice and it cleaned up the excessive ripple current nicely. I guess I should have thought of that earlier. Now I just need to find a sufficient inductor that can handle more then 2 amps.
What is a safe thermal derating for inductors?
The rating on the heatsink I have says C/W/3": approximately .85
So with a 12''/12'' heatsink that makes 144 square inches which should mean .016C per W right?
ronv
Joined Nov 12, 2008
3,770
A schematic of what you have so far might be in order.
Sensacell
Joined Jun 19, 2012
3,451
I think it means .85 degrees / Watt per 3" slice.
That suggests 0.212 Degree per watt total @ 12 inches.
900 Watts X .212 = toasty 191 C temp rise. Gonna need some serious fans.
A choke rated for 8 A is going to be a MONSTER and you don't need it.
Fix up the current sink design to provide tighter regulation, it can remove the ripple as long as you have enough headroom. Is it really a current sink? I don't see a sense resistor?
coinmaster
Joined Dec 24, 2015
502
It's not 12 inches though it's 12 by 12 so 144'' / 3 = 48 .8 / 48 = .016c which should mean 14.96c increase, right?
I didn't post the current sink, just the regulator. I don't know how to make a current sink that can reject nearly the entire AC power supplies worth of ripple and still provide tight current regulation. @ 2 amps capacitors are not going to regulate well and they will sink huge amounts of currents which leads back to the original problem.
Why would I need an 8 amp inductor? If I'm going to derate it wouldn't I want to derate it by x2 at most?
ronv
Joined Nov 12, 2008
3,770
8 amps X 30 volts is 240 watts. Where is the other 696 watts?
coinmaster
Joined Dec 24, 2015
502
You're right. I just found out smps is only considered slow in HF applications. This is both a really good thing and a really bad thing because now I need to learn how to design smps which is very difficult from what I hear :( This is gunna be lame.
