Pre-amplifier circuit
Discussion in 'General Electronics Chat' started by finding_apple, May 28, 2008.
  1. finding_apple
    May 28, 2008
    6
    Hi all,
    Does anyone know how a simple Pre-amplifier circuit of an electret microphone look like?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Now that you mention that, I might have a pre-amplifier project for that kind of mic. That came in a magazine, but it is not copyrighted material (none of the materials inside that magazine are). I will OCR it as soon as I can.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    This schematic is for a super sensitive microphone:
    Connect the microphone to the input. You should consider lowering the gain.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    The preamp for an electret mic is simple:
    1) Use a low noise wideband opamp like a TL071.
    2) Bias the input of the opamp to half the supply voltage.
    3) Have atrimpot to adjust the voltage gain to 22 times.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    here is a simple schematic.
    http://www.mitedu.freeserve.co.uk/Circuits/Audio/ecmmic.html
    As you see there is a resistor from the mic to plus.
    Did you use this also? if you forget this your signal will be very low.
    Greetings,
    Bertus
  7. finding_apple
    May 28, 2008
    6
    i think the circuit is too complicated for my case. I decided not to use the preamp for the mic. Thanks.
    Rgrds,
    apple
  8. finding_apple
    May 28, 2008
    6
    Hi i decided not to use preamp in my circuit. now i try to create a DC offset value of 2.5V at the o/p by biasing it with resistors 200k and 100 ohm with the gain of the op-amp=1001. But why the o/p nearly 0v, why the amplification is not done?
  9. finding_apple
    May 28, 2008
    6
    Hi bertus,
    The biasing of the electret is done internally. the circuit start from the mic(+pin) to a 2.2k resisitor then to a capasitor the to resistors 200k and 100 acts as a voltage divider to supply 2.5mv to the op-amp then with gain of 1001 , i hope to amplfy the CD o/p to 2.5v . But why the o/p nearly 0v, why the amplification is not done?
    Regards,
    apple
  10. finding_apple
    May 28, 2008
    6
    Hi bertus,
    The biasing of the electret is done internally. the circuit start from the mic(+pin) to a 2.2k resisitor then to a capasitor the to resistors 200k and 100 acts as a voltage divider to supply 2.5mv to the op-amp then with gain of 1001 , i hope to amplfy the DC o/p to 2.5v . But why the o/p nearly 0v, why the amplification is not done?
    Regards,
    apple
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    hello,
    Can you post a drawing of your schematic?
    Greetings,
    Bertus
