pre amp assistance please
Discussion in 'The Projects Forum' started by Neil Groves, Apr 12, 2012.
  1. Neil Groves
    Sep 14, 2011
    125
    Hi Guys, well i just got around to finishing my colour organ and all is now fine when i apply a line level signal, i now wish to add a pre amp at the front end so i can select either mic or line to drive the circuit, i don't know much about pre amps in terms of input/output voltages but i am assuming with a mic insert, i am dealing with a few micro volts? i need to raise this to a couple hundred millivolts using an op amp since i have one half of a dual op amp unused on my board, i can't seem to find a circuit online surprisingly, could someone point me in the right direction please?
    Neil.
  2. #12
    Nov 30, 2010
    16,705
    7,354
    While you're assuming a mic insert, you will need to assume exactly which microphone and what loudness it will be hearing. That can make the difference between a single millivolt and 3 to 4 whole volts (p-p).
    Humans can enjoy music from maybe 60 db to 120 db. That is a HUGE difference in voltage gain.
  3. Neil Groves
    Sep 14, 2011
    125
    it needs to pick up music at a comfortable level in the room and generate enough voltage to drive filters made from an op amp I.C
    Neil.
