practically calculating phase difference between voltage & current
Discussion in 'Homework Help' started by brihad_jy, Sep 9, 2009.
  1. brihad_jy
    Sep 9, 2009
    I am working on a project named automatic power factor controller. I need phase difference between the applied AC mains input signal of 230Volts, 50Hz. Can anyone help me, how to practically determine the phase difference b/w Voltage & current of the input signal????
    Thanks in advance
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    voltage and current are delivered inphase, unless you share your circuit with another that has high reactive loads.
  3. mik3
    Feb 4, 2008
    4,846
    63
    Do you have a way to monitor voltage and current?
