I'd like to verify a good rule of thumb for measuring ripple voltage and current.
When taking my measurements, I make sure to set the measurement to AC coupling peak to peak measurements for voltage at about 5-10mV/Div.
For current I do the same with 10mA/Div
I also make sure to use a grounding probe (voltage measurements) with shortest run to remove effects of inductance.
Any advice?
Any advice?
