Practical Op Amp uA741
prescott86
Joined Mar 28, 2009
Referring to the attachment, value of Vo and Ib can be obtained from pspice simulation. My question is, how I'm going to calculate Vio? Since Rc(R1 // Rf) is implemented, do i need to consider Vos due to input offset current?
Thanks for reading this, any help would be highly appreciated.
hgmjr
Joined Jan 28, 2005
9,027
I can't seem to open the attachment you have provided. Are you able to open it and see its contents?
hgmjr
Wendy
Joined Mar 24, 2008
23,429
First, something a bit more readable, I'll think about it...
I'm not sure what parameter you are refering to as Vio, but I would say what I'm seeing is offset. Try adding a offset pot and see.
hgmjr
Joined Jan 28, 2005
9,027
I suspect that once you get down to values of currents in the nanoamps and picoamps you start encountering rounding errors in the circuit analysis program. I believe this is the reason that the application of normal opamp circuit analysis begins to yield conflicting results when compared with the simulation.
hgmjr
