PPM error calculate formula
Discussion in 'Homework Help' started by sen_embedded, May 10, 2010.
Thread Status:
Not open for further replies.
  1. sen_embedded
    May 9, 2010
    Crystal frequency = 32.768KHZ
    PPM =20 PPM
    Temperature =25 C
    I have used above crystal in RTC. I am getting 1.4 sec delay per day can you please let me know how calculate the error.
    Please let me know PPM error calculate formula
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The error is 1.4 sec per 24 hours
    Error[PPM]=1e^6*1.4/(24*3600)=16.2037 PPM
    which is within the error spec. of 20 PPM @25C for your crystal.
  3. sen_embedded
    May 9, 2010
    Actualfrequency = 32768 (Hz)
    20 ppm frequency =32768-20 = 32748
    Actualfrequency per day = 32768 * 3600 * 24 = 2831155200
    20 ppm error frequency per day = 32748* 3600 * 24 = 2829427200
    Error frequency per day = 2831155200 – 2831068800 = 1728000 Hz /per day
    frequency = 1728000 /1000000 = 1.74 sec
    20 PPM error in 32.768 Khz. crystal oscillator = 0.5 Sec per day
    Pelase let me know my caluation is right or worng
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Crystal frequency is irrelevant.
    Max error per day is (60*60*24) * (20/1000000) = 1.728
    ........................seconds in day * error
  5. rjenkins
    Nov 6, 2005
    1,015
    69
    If you want ultimate accuracy, use a crystal that needs a higher capacitive load that the oscillator in the chip provides; ie. the common crystal osc config with a capacitor to ground from either side of the crystal.
    Now make the capacitor at the oscillator input side a variable one - a trimcap, of about twice the nominal fixed capacitor value.
    You can then tune the oscillator to exact frequency and minimise any error.
    If you need better stability still, you also need to temperature stabilise the crystal, or preferably the whole oscillator circuit.
  6. retched
    Dec 5, 2009
    5,201
    313
  7. Martino Chiro
    Member
    May 1, 2015
    56
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What is PPM here?
  9. R!f@@
    Apr 2, 2009
    8,791
    771
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    anyway what is it?
  11. R!f@@
    Apr 2, 2009
    8,791
    771
    Open a new thread if you have a question.
    Isn't that what you always do.
    Better yet type that in google and read the articles for a change.
    You are not a baby to ask things that you can find for your self.
    https://www.google.mv/?gws_rd=ssl#q=PPM+crystal+error
    I get tons of info and why can't you. Don't be lazy. Try to read for your self.
    What makes you think you would understand any better here than from google.....!
    RRITESH KAKKAR likes this.
  12. WBahn
    Mar 31, 2012
    18,087
    4,917
    MOD NOTE: Thread closed -- necroposting.
Thread Status:
