Nothing wrong with that, and I will use it when I have access to it. I'm planning on using the RPi in the forest. Off the grid.What is wrong with using almost any 5V mobile phone charger? Or the supply that came with the Pi?
I read somwhere that is uses something between 500-800mA. Adding a heatsink, will not be any problem. Of course that mA is dependent on what I'm hooking up to it. For now, its only that Pi Cam.If you're planning on drawing 1A from the 5V supply then the regulator would have to dissipate 7W. It would need a LARGE heatsink. Your circuit board doesn't seem to make allowance for any heatsink. The 1N4004 will be running at its rated maximum; not good practice.
Thank you.Till then ta ta...!
by Duane Benson
by Jeff Child
by Jake Hertz
by Duane Benson
