Powering Op Amps
Discussion in 'The Projects Forum' started by magikal, Dec 26, 2008.
  1. magikal
    Thread Starter Active Member
    Nov 23, 2008
    31
    How do I generate the negative voltage reference required to power an op amp? I want to use the non-inverted op amp configuration to multiply. BTW I have the LM3900 quad amp chip and the LM1458 dual amp. Is there a simple circuit to generate the negative voltage source?
    Thanks for the help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will need to make a power supply to do that correctly. Use a center tapped transformer and bridge rectifier to make the positive and negative voltages - http://www.allaboutcircuits.com/vol_3/chpt_3/4.html. A pair of three terminal regulators will complete the power supply.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Opamps do not need a negative supply if their inputs are biased at half the supply voltage. Then the input, output and feedback-common might need coupling capacitors.
    An LM3900 is obsolete and had very unusual inputs.
    The MC1458 is a dual lousy old 741 type. It has poor performance today.
  4. magikal
    Nov 23, 2008
    31
    what op amps are good and cheap?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    I use TL071 single, TL072 dual and TL074 quad low noise, low distortion and fairly wideband opamps. They cost $.53US for one TL071, $.50US for one TL072 and $.48US for one TL074 at Digikey today. They have thousands in stock in many different packages.
  6. gee_emm
    Jan 16, 2008
    34
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
  8. John Luciani
    Apr 3, 2007
    477
    For low currents look at the ICL7660. One IC (8 pin dip) + 2 caps to generate a negative supply (similar idea to the 555 schematic that was posted).
    It is low current and unregulated but for a bias supply you may be OK. Some
    versions of the chip add regulators. Intersil, Maxim, TI, Linear Technology and Analog
    Devices all make various versions of these devices.
    (* jcl *)
  9. magikal
    Nov 23, 2008
    31
    Thanks for the help, I figure it out. Does anybody know a good analog cheap squaring chip? The input range only has to be -1V to 1V or so.
    I've looked at the AD532, but its a bit too expensive for me.
