Hi.
Am building a device that it should turn itself on when wetted/submerged, off when not.
There is a 4V lithium cell inside. Needs to be recharged once every while.
The hermetic sealed-for-life case should have external contacts for charging the cell on a craddle and to sense water.
If contact 1 is cell +
If contact 2 is a pulled-down mosfet gate to turn the unit on,
Then, the turn-on feature could work.
But a contact 3 is also needed for common negative to recharge the cell. If there is a negative contact exposed to water/seawater; the gate may not turn on; and the power contacts may corrode by electrolysis.
Is there a circuit strategy that will avoid or greatly diminish the contacts erosion? I wonder if a diode at the minus terminal, allowing recharge but blocking electrolysis current works. Then the charger would have to supply just 0.7V extra.
Any suggestions ?
Edited : added - something like this ? :
Any suggestions ?
