Powering my project, need help plz
Discussion in 'General Electronics Chat' started by jakethehusky, Apr 2, 2016.
  1. jakethehusky
    Mar 24, 2016
    22
    I just finished my rgb controller that works with pc via an Arduino nano. I use mosfets to use the higher current, for powering the rgb ledstrip I need 12V DC and around 0,700 A. I don't have any adaptors/transformers laying around that would work out.
    What would be the best place to buy one? Is there anyway around using another one and modifying it ?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    What are your size limits? One option is to get a discarded PC and use its power supply. I still use one.
    Another option is MPJA or Jameco/ Each has lots of inexpensive supplies
    http://www.mpja.com/
    http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&categoryName=category_root&subCategoryName=Power Supplies & Wall Adapters&category=45
    You will need to choose between an open chassis, enclosed unit, or wall wart.
    There are also numerous surplus dealers, like Electronic Goldmine, Allelectronics, and Surplus Center.
    http://www.surpluscenter.com/
    http://www.allelectronics.com/
    http://www.goldmine-elec-products.com/
    Finally, you could consider a battery charger. If you go that route, I recommend using a 12V regulator.
    John
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,296
    225
    Just a reminder, 12 VDC and current greater than or equal to 0.7A (700 mA). 12 VDC @ 1 A is a common adapter.
    ICmaker likes this.
  4. Dodgydave
    Jun 22, 2012
    5,169
    777
    Use an atx psu, or laptop psu.
  5. InspectorGadget
    Nov 5, 2010
    211
    42
    Laptop PSU's are usually 16-19V. I don't think he needs that much.
    An ATX PSU is often load-dependent. You might have to put a load resistor on the 5V to get the 12V to work.
    Better to find a 12V brick somewhere. Any electronic catalog will have one, surplus store will have one even cheaper.
  6. jakethehusky
    Mar 24, 2016
    22
    I am looking around trying to find an old 12V 1A adapter, so far no luck. What is the best place to buy these ?
  7. Dodgydave
    Jun 22, 2012
    5,169
    777
    Ebay, second hand shops, buy and sell, car boot....
  8. djsfantasi
    Apr 11, 2010
    2,914
    881
    Amazon, Adafruit, Digikey, ...
  9. KeepItSimpleStupid
    Mar 4, 2014
    1,296
    225
  10. wayneh
    Sep 9, 2010
    12,405
    3,256
    For what it's worth, the power supplies that ship with a lot of computer peripherals (hard drives, routers) are 12V and are rated to supply 1A or more. If you have an electronics recycling spot anywhere nearby, you can probably grab a few of them for free.
