I've read through some threads here and I'm hoping to summarize what I want to do and see if I understand it correctly. I have built several little electronics kits (wheel of fortune, blinky, sound generator, etc.) for this first question let's assume they all run on there own 9 Volt battery.
Yes or No (or it ain't that simple)
Can I use a single 9 Volt wall wart to power all of these kits as long as I don't exceed the total combined amperage of the devices?
Question 2, let's assume for this one that 3 of the kits use a 9 volt battery and 3 of them use 3 volts.
I'm assuming that I can wire up the 3 9 volt ones directly. How do I step down the 9 volt Wall Wart to power the 3 volt kits?
In my head I'm thinking I take a 9 volt lead from the wall wart and hook it to some type of step down circuit and then run the 3 volt leads off of that circuit. Again I'm thinking as many 3 volts as I want as long as all kits (3 & 9 volts) don't exceed total amps of the Wall Wart.
Really appreciate your help on this. My ultimate goal is to build a panel of 8 - 10 of these kits powered off a Wall Wart so I can power any one or all of them without having to deal with battery replacements.
Thanks a bunch,
Dennis
Thanks a bunch,
Dennis
