Powering led's, 9v battery not enough.
Discussion in 'The Projects Forum' started by hashmaster, Oct 17, 2013.
  1. hashmaster
    May 30, 2012
    42
    Trying to add led lighting to my rc car. Ive averaged the pwm, got my comparator working, fed that into the base of a 2n3904, emitter to ground, collecter to the led cathode, anode to positive rail. Yay led lights. Added more led's in series, no more light. Well figured that was wrong, so I tied all the cathodes together and set all the anodes to their own positive voltage. Yay they all light, but for all of about 10 seconds or so. Im using a 9v battery for the source of the comparator, and the led's. With two bright white led's, two red led's, and eight green led's a new 9v battery lasted like I said about 10 seconds if that. I an using a fighre of about 20mA for each led, sincei dont have datasheets for them, I figured a 9v should last longer.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    The word, "resistor" was not to be seen in that post. If you didn't use any resistors, you might have smoked something. A part! I meant you might have smoked a part!
  3. shteii01
    Feb 19, 2010
    3,507
    512
    Try two 9 V batteries in parallel.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    That would help reveal the presence of runaway current failure.:p
  5. hashmaster
    May 30, 2012
    42
    Hahaha yeah forgot resistors somehow in the first test, second test I used a few various resistors from 330ohms and 470 ohms with 4 less green leds, had just a little bit more light time but my white leds disnt light. I dont quite wanna start stacking 9v in parralel for more capacity because 9v batteries are pricey, and im cheap.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    Use your 470 ohm resistor and a 9V battery and measure each LED for its personal forward voltage. Then report back here with how many and how much and we'll see if we can design something that works.
    ps, you can't run all of them in parallel because 12 x .02 amps is a quarter of an amp. Way out of the range of a 9V battery.
  7. hashmaster
    May 30, 2012
    42
    Alright 9v battery voltage is 7.74V. The green leds measure at 2.045V, 2.05v, 2.10v, 2.07v, 2.07v, 2.08v, 2.08v, 2.1v. The white leds are 2.71v, 2.75v. The red leds are 3.73v, 3.81v.
  8. shteii01
    Feb 19, 2010
    3,507
    512
    Do you have them all in parallel with the battery?
  9. shteii01
    Feb 19, 2010
    3,507
    512
    Why I suggested a second battery.
  10. hashmaster
    May 30, 2012
    42
    They were all measured independently. 1 resistor 1 led.
  11. #12
    Nov 30, 2010
    16,704
    7,354
    When the failure time is 10 seconds, and everything is right about the circuit, a second battery will only change the failure time to 20 seconds. Not enough to satisfy the customer.
    Personally, I design for 7 volts = end of battery. Now I will go play with the calculator for a while and tell you what the results are.
    BRB.
    ps, Red LEDs are supposed to use less voltage than any other color. Could you double check with a fresh battery?
    hashmaster likes this.
  12. shteii01
    Feb 19, 2010
    3,507
    512
    Sorry. I did not mean your measuring technique. I mean the final circuit, all LED will be parallel to each other and parallel to battery, right?
  13. hashmaster
    May 30, 2012
    42
    Kinda my orignal thoughts
  14. #12
    Nov 30, 2010
    16,704
    7,354
    I must get a second measurement on the reds. I doubt your answer and I can't even get 2 reds in series to work at the voltages you listed.
  15. #12
    Nov 30, 2010
    16,704
    7,354
    This is the first shot. If your numbers were right, this will work. (Every LED that is not labeled is green.)
  16. hashmaster
    May 30, 2012
    42
    Although the led light xant quite be seen it is lit.
  17. hashmaster
    May 30, 2012
    42
    Shall go give it a try. Thanks.
  18. #12
    Nov 30, 2010
    16,704
    7,354
    ps, 7.74V is pretty used up for a 9V battery. Watch for the battery voltage to fail as you get toward 100% "on" time.
  19. hashmaster
    May 30, 2012
    42
    Well had to go to radio shack since I only had one resistor fromthat schematic. Also using a 680 ohm resistor on the base, and got a fresh 9v battery. Its at least 6x more efficient then before. Left it running for about a minute before I pulled the power. Battery still metered 9.25v. Thanks #12. Could possibly give me a brief explanation on how you calculated that out too?
  20. shteii01
    Feb 19, 2010
    3,507
    512
    Resistor for LED==(Supply Voltage - LED Vforward)/20 mA
    Example:
    (9 V - 2.71 V - 3.73 V)/20 mA= 128 Ohm (he rounded down to 120 Ohm)
    Power for resistor == I*I*R == 20 mA*20 mA*120 Ohm=0.048 W (he round it up to 1/8 W which is 0.125 W for extra safety margin)
