powering led help!!!
Discussion in 'The Projects Forum' started by angryguywalking, Apr 10, 2009.
  1. angryguywalking
    Apr 10, 2009
    hey guys im kinda new to electronics and i need help powering an led.
    The LED is 3.6 V and i want to power it with a battery pack that holds 4 AAA batteries. i know that 4 AAA's=6 V which is too much so i just want to use 2 batteries in the pack instead of four which makes 3 V which will power it enough. does anyone know how to do this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    4 AAA "normal alkali" batteries will give 6 Volts, as each cell will give 1.5 Volts.
    When you use NiMH or NiCad cells the voltage will be lower.
    To power a led, you must know its voltage drop and its current.
    Take a look at this page with led circuits:
    http://www.educypedia.be/electronics/circuitsled.htm
    Greetings,
    Bertus
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A brand new alkaline AA cell is 1.5V to 1.6V. Four in series make 6V to 6.4V, not 9V.
    Your "3.6V" LED might be 3.2V or 3.8V or in between volts. It won't light with only 3V from two battery cells.
    A solar garden light uses an electronic circuit to boost the 1.2V from a rechargeable battery cell to 3.6V to light a white or multi-colours LED.
    Look in Google for Joule Thief. It is a small simple electronic circuit that boosts 1.5V to enough volts to light a 3.6V LED.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. xenon art
    Apr 11, 2009
    I've found another circuit on
    http://control7.net/electronics/single_cell_LED_flasher.html
