Powering an iComSat GSM Shield and Gear Motor using LiPo (Lithium Polymer) Battery
Discussion in 'The Projects Forum' started by macdonaldtomw, Mar 26, 2014.
  1. macdonaldtomw
    Mar 26, 2014
    I have an iComSat GSM Arduino Shield (based on the sim900) and a gear motor that I am planning on using with a Teensy 3.1 microcontroller. I'd like to power the whole rig using a 2000mAh LiPo Battery Cell. The datasheets for the battery and gsm module are attached.
    So I have:
    Teensy 3.1 microcontroller Vin= 3.4 - 4.5V
    GSM Shield | Vin=9-20V _ Iavg=500mA _ Ipulse=2000mA
    Gear motor __ | Vin=6V _ Ifree=70mA _ Istall=1600mA
    LiPo Battery __ | V=3.3 - 4.3 V _ Imax = 2C = 4000mA <--somehow I doubt this... more like 3000 mA probably
    My question is which of the following courses of action should I take, and are there alternative courses of action that I haven't thought of yet?
    1. Use boosting circuits to boost the battery voltage up to 6 V and 15 V for the gear motor and the GSM module, respectively
    2. Use a higher voltage battery source (i.e. 12 or 15V) and use voltage reduction circuits to limit the voltage seen by the servo and microcontroller.
    3. Get a sim 900 GSM module on its own (i.e. not integrated into an Arduino Shield) and use it directly with the battery (the sim900 on its own needs 3.2 - 4.8 V). I would still use a boosting circuit for the gear motor.
    What's the most energy efficient and robust solution? Or is there another solution I haven't though of?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    How long do you require this device to operate on battery power?
  3. macdonaldtomw
    Mar 26, 2014
    I plan on having this unit turn on for about 10 seconds, every 3 hours or so.
    It only needs to be able to send a user-entered PIN # and the cell tower/signal data to a remote server for tracking purposes. Then it waits for the server to respond with a text-based command such as "clear", or "hold".
    I have attached a pdf the communication protocol schema I plan on using to this post.
    The battery will be recharged via a nominal 6V bike dynamo which will run approx 30 minutes per day (at more like 3 or 4 V), which I figure should be enough to keep the battery juiced!
