Powering a single Device with 2 energy sources
Discussion in 'The Projects Forum' started by iONic, Nov 17, 2007.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    Is there a way to power a device with Primarily solar, but in addition, when the situation occurs, with battery power as well?
    In other words, If the solar energy is not sufficient, add the additional power from onboard batteries, NiMH, Lithium ion...
  2. GS3
    Sep 21, 2007
    408
    35
    That's easy and, in fact, it is what is normally done. The solar cells are dumping into the battery when they are active while the device is powered from the battery all the time. Same thing.
  3. iONic
    Nov 16, 2007
    1,422
    68
    Please elaborate!
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    The batteries provide the power to the device while the solar cells charge the batteries.
  5. Salgat
    Dec 23, 2006
    215
    Would you just place the Solar Cell in parallel with the battery with a diode to prevent current from passing back into the cell?
  6. Gadget
    Jan 10, 2006
    613
    In some cases yes, although it is good practice to put a solar regulator between the solar panel and the battery, especially if it is a higher power or 36 cell 12v panel, to prevent overcharging the battery.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A common set-up is to have a photo-voltaic panel charging the batteries through the regulator Gadget describes. The batteries then feed an inverter to provide AC for common household conveniences.
    The inverter is the usually weak link in the chain. If your device is DC, then no inverter is needed, of course.
