powering a reverse/forward motor
Discussion in 'General Electronics Chat' started by cjphelps, Aug 23, 2008.
  1. cjphelps
    Aug 21, 2008
    5
    I have a single phase motor(230V) that can be made to forward/reverse by wiring according to this information:
    CCW:
    L1 --------------- P1
    L2 --------------- T4 -T5
    T2-T3-T8
    P2
    CW:
    L2 --------------- T4 -T8
    T2-T3-T5
    P2
    How would I wire this with a 3 conductor wire to the motor and a reversing contactor?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A double pole double throw contactor that swaps T5 & T8 will do it. Hint - attach T5 to one moving contact and T8 to the other. Draw it out on paper, should be easy.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Hint #2: Have the switch "center off." You want to be able to let the (single phase) motor stop before reversing it.
    John
    Edit: Oops. That may not work so simply. The message is that your reversing switch should only be changed when the motor is stopped. You need an on/off switch as well. I use either an interlocking switch (you can't hit forward without going through stop), a drum switch for reversing (same principle), or separate on/off and reversing switches. The latter is OK, if you don't have too many bozos working it.
  4. cjphelps
    Aug 21, 2008
    5
    Hi John,
    Yes We have a interlock switch.
    What do you mean by center off?
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    "Center Off" is an on-off-on switch. In your case it will be wired as forward-off-reverse.
  6. cjphelps
    Aug 21, 2008
    5
    Gotcha,
    We were given a Allen bradley reversing starter for reversing the AC motor. It is basically 2 contactors side by side connected through a interlock switch.
    I am having trouble finding a wiring example for using such a device. any suggestions?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have a part number/model number for your Allen-Bradley reversing starter?
