A 100V rated DC relay when operated and with 55V across it will definitely not release as the current is sufficient to hold it in the Closed position.If the relay is not used, there is still current going through it but at only 55V. This would be ok, right?
For it to release, one should ensure no more than 10% of rate voltage is applied. Even 10% is kind of doggy and can result in unreliable operation.
For this special case you would need to use a DC48V relay instead.Is there a work around for this so it doesn't remain stuck?
