Ok, so I need to power a 16V max Buzzer [datasheet: http://www.mouser.com/ds/2/252/MSR516NPR-24363.pdf]
Now, I have to work with a 24 V source. I know I could use a divider, but I think the resistors I would be needing have to be either a lot of small ones (1/4W) or a few BIG (>1W) ones. What would you recommend?...
And I'm having trouble modelling the buzzer in a simulator. In the datasheet, it says that it can draw a maximum of 12mA at 16V (I just assumed...), so is it ok to just model the whole buzzer as a resistor (16V/12mA = 1.3k) in series with a 12mA current source? If not, then what should it be?...
