Well you COULD design and print a repeated pattern that the leds and resistors could fit in. then cut etch the whole pattern at once. After that you could cut the completed and etched strips from the pattern. Buy you will want a lot of copper to help with heatsinking.
[ed]
Oh jeez. Youre in for a world of hurt. The SMD LEDs you got are under tabbed. They are usually used in an automated or paste deposit and reflow oven type soldering technique. You MIGHT be able to bend the tabs around to use them, or you may be able to solder them as is if yore good and have a REAL fine tipped soldering iron.
HT-T169NB-5538:
[/ed]
[ed]
HT-T169NB-5538:
[/ed]
