powering 2 modules with single output PSU
Discussion in 'The Projects Forum' started by wasabi, Jun 5, 2012.
  1. wasabi
    Jun 5, 2012
    Hi guys
    im new to electronics and still at a sub basic level, i wanted to ask for sound advice before hand
    i have a single output switching PSU with an output of 15vdc 3a to power my project
    the 2 modules im using both require 15v and both need around 0.5a
    how do i connect both on the same power supply?
    i have looked at similar projects using a toroidal psu coupled with a bridge rec and large smoothing capacitor but i was told by a friend i can not use a smoothing cap with DC, only AC then rectify it?
    some ideas / solution would be great
    i can build basic circuits from scematics so a reg/splitter so open to anything
    thanks
  2. mcasale
    Member
    Jul 18, 2011
    210
    12
    I'm not sure what "modules" you refer to. You said the switching supply provides 15VDC at 3 amps. Just connect this directly (in parallel) to each module.
    What is the output from the "toroidal" power supply - DC or AC?
    Depending on what you're trying to do, you can put capacitors on AC or DC.
    If you're trying to make a DC supply from an AC supply (like a transformer), you'll need to rectify and then filter with a capacitor. Google "full-wave rectifier".
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    +1 Assuming the AC versus DC issue is resolved, just think of your modules as light bulbs being plugged into an outlet. Parallel loads on a single supply.
  4. wasabi
    Jun 5, 2012
    my psu is DC.
    i will connect them in parralel
    thanks for the advice
