Hi all
Been using solar panels to charge SLA batteries for ages, running domestic mains lamps converted to use 12v multi-LED modules in my home. Now I'm ready to go a step further, having a decent amount of stored electricity I want to invert up to 220v AC for laptop power and other light uses.
I havent done any electronics for a long time but used to be capable as a teenager (I'm 33) of building radios and the like from loose components and some of the knowledge remains
This circuit looks promising - seems plausible and not too hard for me to make
12v to 220 transistor inverter using darlington pairs and 2n3055s
Most of the parts are silly-cheap on eBay but I dont like the look of the BD140 PNP power transistor used to drive the base of the 2N3055 output transistors: It says it must be cooled but its a TO-216 / SOT32 format which is difficult to heatsink. (too small, and the sinks are rare)
If I use a TO-220 package TIP32C transistor in its place would the circuit still work as intended? I dont properly understand the gain calculations as they would be applied to a darlington pair driver circuit, the maths is a bit beyond me but it appears the TIP32C has roughly equivalent specs but at a higher power
Would it then need less cooling and last longer / run cooler ? Or would putting a higher power rated part there unbalance the circuit, needing different resistances to get the right power on the final drive to the 2N3055 ? (which will be both on big heatsinks)
Massive thanks in advance from this amateur.. I'm here to learn
