I have a QM300HA-24 power transistor. I had another transistor driving the base of the bigger transistor with 14.8vdc. I have 23vdc into the collector. Why do i have round 20vdc coming out of the emitter??...i need 14 or so....does the internal diode across the collector / emitter have something to do with it?? After more testing i found out that 20v is also on the base of the the bigger transistor feeding back into the emitter of the smaller transistor..whats up??
