power transistor check
Discussion in 'General Electronics Chat' started by jody, Jun 1, 2013.
  1. jody
    Nov 12, 2012
    39
    hi
    i have a bux 127 power transistor. when i check between c an e with multimeter on diode check should it be open reading either way round. if i check a smaller low power transistor that is what i get. the transistor is new from a lucky bag so i assume its ok.
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    c to e should appear open in both directions
    bux127 is a darlington and hence don't expect the same readings as with a regular NPN BJT when reading b to c and b to e.
    jody likes this.
  3. jody
    Nov 12, 2012
    39
    thanks
    in one direction on c and e im getting .700 on the meter and the other open circuit, could this be because its a darlington type.
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    Thats because there is a diode across the C/E terminals
    jody likes this.
  5. jody
    Nov 12, 2012
    39
    thankyou
    i just found a data sheet for it and see the diode.
