Power Transformer
Discussion in 'General Electronics Chat' started by john_cover, Mar 15, 2012.
  1. john_cover
    Mar 15, 2012
    Hi!
    good day to all.. Im newbie in area... need assistance
    What is the best correct equation, computation, formula for the given values below..
    Power Transformer E I lamination
    P= 1KVA
    Primary input voltage = 0v-220v-240v
    secondary output voltage = 50v-0v-50V center tap
    Frequency = 60Hz
    Core Area?
    Number of turns per volt primary and secondary?
    size of wire primary and secondary?
    :confused::confused::confused:
    BR
  2. john_cover
    Mar 15, 2012
    up up for this thread
    by day this is for E and I core silicon steel lamination
    and uses 1.2kg flux density...
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Apparently nobody here winds their own 60 Hz. power transformers. I can only suggest that you get the specifications from the manufacturer of the laminations as they vary from manufacturer to manufacturer.
