Power Transformer
Discussion in 'Homework Help' started by ydheeraj, Mar 1, 2012.
  1. ydheeraj
    Dec 7, 2011
    Do a Power Transformer is operated at full load condition only and is disconnected under light load condition ??
  2. crutschow
    Mar 14, 2008
    13,523
    3,390
    A transformer can be disconnected loaded or unloaded. Makes no difference.
  3. ydheeraj
    Dec 7, 2011
    sir,
    i want to know that whether practically a power transformer is operated at light load condition or not?
  4. panic mode
    Oct 10, 2011
    1,330
    305
    yes, you can vary load from 0 to 100% without problem. Usually they are not operating at full load.
  5. amilton542
    Nov 13, 2010
    494
    64
    It depends on how the load varies, and the voltage drop along the way to consumers.
    Typically, it will be a load tap changing transformer (LTC) that will keep the voltage amid nominal limits due to utility politics.
