Power trans.
Bichrome
Joined May 2, 2014
12
Hello!
I recently got Denon PMA520 vintige stereo amp. for free, but it has a dead power transformer. I want to fix it, but i don't know what kind of tranformer i need. All i know that originaly it has torodial transformer with 37,2 V in second winding.
Can I use laminated steel core transformer?
Can I use transformer with 40V in second winding?
I attaced schematics and some photos of the amp.
I have only basic knowledge about eletronics and realy need your help to sort this out.
Thanks!
#12
Joined Nov 30, 2010
18,224
I told the moderators you were having difficulty getting your attachments to show up. Somebody will probably be along to help you with that.
Georacer
Joined Nov 25, 2009
5,182
It seems that you have not uploaded the attachments successfully in the server, which is weird, since you have received attachment ID codes. Can you repeat the process one more time?
Edit the message, use the "Go Advanced" button and re-upload your pictures.
MaxHeadRoom
Joined Jul 18, 2013
28,702
If you are in N.A. there is Antek that makes Toroidal transformers.
He also lists on ebay as Jonango.
The reason for toroidal in audio equipment is the magnetic field is contained within the core, so hum problems are kept to a minimum.
The diameter and height will indicate the Va required.
Max.
Georacer
Joined Nov 25, 2009
5,182
You probably couldn't edit your post because your post count is under 10 and you are thus classified as a New Member. I always forget class permissions.
Sorry for the confusion.
#12
Joined Nov 30, 2010
18,224
I can tell you this: You're looking for a transformer that is probably rated as 75 volts, center tapped, or 37.5-0-37.5 give or take a volt or two. The power rating will be less than 460 watts which I derive from 230 VAC input and a 2 amp fuse. The power rating might be quite a lot less, like 200 watts.
The manufacturer went to considerable expense to make this a toroid AND shield it with a metal can. Trying to use an open frame transformer is begging for trouble.
studiot
Joined Nov 9, 2007
4,998
I recently got Denon PMA520 vintige stereo amp. for free, but it has a dead power transformer. .................
................I have only basic knowledge about eletronics and realy need your help to sort this out.
How do you know the transformer is dead?
Bichrome
Joined May 2, 2014
12
Ok, it's the help what I was looking for!
So it's ok to use 40,0-0-40,0 V torodial transformer?
1) Transformer did not show any voltage in secondary winding when I connected transformer to 220V.
2) Transformer's primary winding didn't show any resistence reading when i connected it to digital multimeter.
3)Transformers primary winding does not conduct eletricity.
Is there any other way to check transformer?
Bichrome
Joined May 2, 2014
12
Max.
I'm from Latvia so shipping would be expensive...
And I realy can't get toroid out of it's metal case because it is filled with polyurethane putty, to get out toroid I have to destroy either toroid or metal case.
Bichrome
Joined May 2, 2014
12
Obviously you've checked for a blown fuse in series with the primary winding?
Fuse was the first thing that I checked, and the fuse is ok. But how it comes, that there is dead toroid with intact fuse?
It looks as though you have removed the transformer for testing, so it also looks as though you need a new one.
These people are specialists
http://www.ilpelectronics.com/images/pics/transformers_mains.pdf
Yup I have removed it.
I have found toroid in my local electronics shop. 40-0-40 V 5 A in total for 220V. Those excess ~2,5 V should not do any harm....am I right?
studiot
Joined Nov 9, 2007
4,998
The simple way to deal with a slightly higher output from the transformer is to add one or more power rectifier diodes in series with the feed from the main rectifier bridge to each rail.
This will lower the rail voltages to normal levels without huge power disipation or complicated circuitry.
Is this enough information or do you need more detail?
Bichrome
Joined May 2, 2014
12
So all I must do is to put one or more power rectifier diodes after the original power rectifier diode bridge?
I have attached png. file to show what i mean and photo with
s4vb bridge rectifier.
MaxHeadRoom
Joined Jul 18, 2013
28,702
If you are absolutely sure it is the transformer, I would tackle it as you have nothing to lose.
If it is hard epoxy it usually chips away.
Extremely rare for a transformer to go open.
Max.
