Power System/transformer question
pppopey
Joined Sep 27, 2011
13
attached is the question i am trying to solve.
I do not know how to do per unit questions.
Part a) of the question ask to convert into per unit and then per phase equivalent circuit. I do not understand how to do it. Please guide.
Also, how to calculate the bus1 voltage?
mlog
Joined Feb 11, 2012
276
The values of voltage, current, VA rating, and impedance are expressed in a per-unit (p.u.) system, which is a percent expressed as a decimal. Usually the "base" of the system is a kVA and kV rating. From those, the base current and base impedance can be calculated. For single-phase systems and per-phase values, the per-phase kVA and line-to-neutral kV can be used as the bases. In your problem, you have been given the kVA rating and the kV value for the base.
Within any part of a system, the impedance must be expressed in the same p.u system. It may be necessary to convert from another p.u. system.
