Power System Design
Discussion in 'The Projects Forum' started by Sleepcakez, Apr 7, 2011.
  1. Sleepcakez
    Jun 26, 2010
    13
    I'm in charge of designing the power system for our senior design project, and I'm in need of a little help actually building a circuit. We are building a hand held device that will be doing range finding and IR temperature reading. We've got it pretty much determined that the project should run off a 5v source. I intend to use Lithium Ion cells to power it. We have also determined we are going to need a LM7805 and possibly a LM7905 for a +-5v regulator.
    If anyone can point me in the right direction for starting to build a circuit or some good information on what I need to be doing, I'd appreciate it.
  2. debjit625
    Apr 17, 2010
    790
    186
    Download the datasheet of LM7505/7905 in their you will get help on application design using them.
    Good Luck
