power supplycircuit
Discussion in 'General Electronics Chat' started by valencia, Jun 22, 2014.
  1. valencia
    Jun 22, 2014
    Hello, every one i would like to know what will happen if you mistakenly put a 12vAC to a 12vDC circuit.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Chances are the circuit will be destroyed.
  3. Dodgydave
    Jun 22, 2012
    5,163
    774
    +1, unless its got an input diode or full bridge, Boom!
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    The 12Vdc circuit only allow the current flows through from one direction, but the 12Vac providing a bi-direction current, will it blow up the EE parts, it depends on do the parts can be bear the reverse voltages or not.
  5. Ramussons
    May 3, 2013
    562
    92
    If you are Lucky, no damage might happen. Feed the correct voltage and test.
    Ramesh
