https://www.phoenixcontact.com/assets/images_ed/global/web_content/pic_con_a_0041942_int.jpg
Hi, I have a question about the dc/dc converter on the right and how it works.
If I only put a 200V input into the left most terminal (L+), will I get a single +24V input on the other side? Is it assumed that these converters have an internal (ground) reference?
Or is it wired so that I need to put a ground in the N- terminal at the bottom? If I were to put in +200V on the left and -200V on the right, would I get +24 and -24V at the output? Why is there 2 negative output terminals at the top, and what is the DC OK terminal for? Same goes for NC, I'm not sure what that does either.
Thanks for all replies! I hope I was clear in my question, since my understanding of this is quite remedial.
Cheers!
Cheers!
