power supply
Discussion in 'The Projects Forum' started by paulopca, May 23, 2013.
  1. paulopca
    Apr 16, 2011
    14
    Hello to all!
    I need help to develop a power supply that is capable of receiving the input 12Vdc or 9VAC rms and delivered to the output +12 Vdc and -12Vdc with capacity of up to 8W of power.
    Attached is the circuit I'm trying to use and need to determine the values of the components.
    If anyone has a better suggestion for a circuit that does not need transformer to generate the positive voltage and negative and use in place of the transformer capacitors shall be very grateful to anyone who can day provide.
    Thanks to everyone who can help me.
    Best regards
    Paulo
  2. t06afre
    May 11, 2009
    5,939
    1,222
    What is the background for your specifications, and how did you end up with that circuit
  3. paulopca
    Apr 16, 2011
    14
  4. t06afre
    May 11, 2009
    5,939
    1,222
    So you want make a power supply for that mixer unit you posted a link to? what is probably something we can help you with. But I would say you are on the wrong track with your schematic. Let us first start with your AC voltage what is the source of this. Is it a transformer? Then designing a power supply it kind of important to get the specs on the transformer correct. So let us start in that end.
  5. paulopca
    Apr 16, 2011
    14
    I found the wiring diagram on the Internet that mixer and tried to assemble.
    The oscillator did not work with the transistors shown in the diagram. It worked when I rode using BC546.
    The negative voltage of-12Vdc only reaches -4Vdc.
    Attached is the schematic.
    I was looking for an idea for a power supply that could work with 120Vac and 12Vdc generating output +12 Vdc and-12Vdc but did not use transformer to produce the positive and negative voltages, I found this project and tried to build, but did not work as is in the scheme.
  6. LDC3
    Apr 27, 2013
    920
    160
    There is a connection error. The gate on Q4 needs to be connected to R4, not R3.
  7. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    You can use something as simple as a 555 timer to create a negative voltage if your input voltage is low. I seem to recall using one to create a dual rail supply for an op-amp comparator in the past.
