Im a beginner. In a project im assigned to use 9V battery, I have a variable power supply. Can I use it with 9V selection instead of battery? Pls help me out
A circuit normally takes only the current it needs at a given voltage. So you just need a power supply that will supply more current then that. Any power supply excess current capability is just ignored by the circuit.Thanks, so small difference in current will not matter??
