Power supply
Discussion in 'General Electronics Chat' started by Awesome Girl, Apr 11, 2013.
  1. Awesome Girl
    Apr 11, 2013
    hi! I'm working on a project that involves different apparatus. one of which is unregulated variable voltage DC power supply.
    The instruction says:
    "A shop built dual unregulated variable voltage DC power supply.
    This supply was built from two 0 to 90 VDC power supplies that
    were designed to supply power for permanent magnet DC
    motors with a 90 volt armature circuit. This makes available a
    variable DC voltage of 0 – 90 volts at 10 amps. Power supplies
    for releasing brakes up to 90 VDC. Second supply is for lockingup the rotor for alignment checks."
    I need to build the supply but I'm still confused about how it has to be done. I was thinking of getting two 0-90V unregulated variable voltage DC power supplies and connecting them in series. This doesn't seem right to me though!
    Is there any other way that I can build this supply?
    Thank you
  2. Eric007
    Aug 5, 2011
    1,054
    33
    Welcome to the forum!
    Hope you get some fun here...:)
    And gudluck with your project!
    Awesome Girl likes this.
  3. Brownout
    Jan 10, 2012
    2,375
    998
    How much have you worked around voltage this high? I hate being the nanny goat, but this voltage can kill, and I'd be irresponsible to encourage someone do proceed if they aren't experienced in working with lethal voltages.
    Awesome Girl, absf and Metalmann like this.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Putting (2) 90 volt supplies in series would make 180 volts, and that is not at all what you need. That is easily enough to kill you. The fact that you asked in this way makes us worry.
  5. Mike33
    Feb 4, 2005
    349
    25
    AWFUL lot of current going to that motor...like they said...there's definitely the potential for a bad, bad safety problem here!!!
  6. Mitch conrad
    Apr 10, 2013
    7
    It sounds like you working on some industrial application, there should be a manufacturer that could supply you with the right parts if that's the case. If so it would be best to try other alternatives before trying to build a high voltage power supply.
    You could even cannibalize power supplies from equipment with similar specs if you want to go cheap.
    I don't know how experienced you are ,but if you are inexperienced with high voltages building a power supply like this could be a bad idea.
  7. Awesome Girl
    Apr 11, 2013
    Hi! thanks for your replies. I don't have experience at all. I am working on my first project in an industry and it requires equipment that we don't have. when going through the list of equipment we need I saw that instruction about the power supply.
    I thought we needed to build it but I don't wanna die now.
    I'll try to find out manufacturers who can supply it.
    Reading the instruction again makes me think that we might not even need a dual power supply. We can just have 2 supplies, 1connected to release the brake and the other connected to the rotor. Am I right?
    All I need for now is to tell my superior what we need and how we can make or get it.
    Thanks for your help
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    It sounds like you are trying to align Brushless DC motors to their encoders. You will need two supplies. You will need a power supply to release any brake that the motor may have. Some are 90VDC and some are 24VDC, so a variable DC supply is in order. As for supplying power to provide lockup for alignment, it really doesn't take that much DC volage to be able to lock the rotor into a position but current may be higher than you would expect. After all, the only resistance is what is in the windings. A variable voltage is appropriate since you don't want to put more power into the windings than is needed to accomplish lock-up.
    The links below will show you two examples of what should work for you.
    http://www.mpja.com/0-120V-1A-Variable-Benchtop-Power-Supply/productinfo/9312%20PS/
    http://www.mpja.com/0-30V-0-3A-Variable-Benchtop-Power-Supply/productinfo/9616 PS/
