Power supply
Discussion in 'The Projects Forum' started by Tigerlord, Feb 26, 2007.
  1. Tigerlord
    Feb 26, 2007
    i have a power supply of 18V DC constant ....i want to convert it into varible power supply of about 0 - 18 V DC can any 1 tell me the needed circuit
  2. Johann
    Nov 27, 2006
    190
    30
    Many posibilities! What is the max current capability of your 18Vdc supply and how much current output do you require? Tell us more about what you intend using the power supply for.
  3. beck
    Member
    Nov 27, 2006
    26
    1) a variable voltage regulator (LM317)
    2) resistor (R1)
    3) pot(R2)
  4. beck
    Member
    Nov 27, 2006
    26
    oh yes,
    you will have to use 2 diodes at the output to get the voltage down to zero.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    The only alteration I would recommend to Beck's suggested solution would be to use an LDO (low drop-out) linear voltage regulator such as the LM1117-ADJ in place of the LM317 linear voltage regulator that he recommended. The datasheet link provided also has some good application information in it that will help you get aquainted with the way to connect it up to your 18 V dc source. Once you open the link, you will need to scroll down a page or two since the first page appears to be blank.
    The older generation of linear regulators required a couple of volts between the input voltage and the output voltage which limited how close the output voltage could be adjusted to the input voltage.
    The LDO voltage regulators requires as low as 1 volt and so for 18 volts, the output could be adjusted very close to 17 volts.
    hgmjr
