power supply
Discussion in 'The Projects Forum' started by jimit, Nov 16, 2010.
  1. jimit
    Oct 28, 2010
    57
    at last i found a working pc power supply
    and i made it but there is one problem i get a little shock from the metal body
    what would be the problem
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Is the ground (earth) connected at the mains side?
    If not there can be some tickling due to the missing ground.
    Bertus
  3. kubeek
    Sep 20, 2005
    4,689
    806
    Wrong grounding? Did you change anything on the PSU?
    If you did then all I can say to you is: keep at it, hopefully you will get a Darwin award.
