power supply wiring Question
Discussion in 'General Electronics Chat' started by djh10, Oct 29, 2014.
  1. djh10
    Oct 29, 2014
    6
    +Vs needs 7.5V, -Vs needs -2.5V, GND is ground, VDD needs 4.75/5V
    my question is where to the wires go into the power supply which configuration.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    What is that instrument? Show us the full front panel.
    You need a power supply to provide the three voltages specified.
  3. djh10
    Oct 29, 2014
    6
    yeah its a triple output DC power supply
  4. djh10
    Oct 29, 2014
    6
    got it working, phew!!
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    Assuming that the +25V and -25V suppies are independent, connect the two BLACK and one GREEN terminals together.
    Use the +6V supply adjusted for +5V.
    Adjust the +25V supply for 7.5V.
    Adjust the -25V supply for -2.5V.
  6. djh10
    Oct 29, 2014
    6
    yeah thats what i did,only i put wire from GND into the COM port, results are as i wanted
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    Be aware that the Green post is connected to the building's earth (electrical panel) ground through the third prong of the power supply's AC Line cord.
    You may or may not want to connect the circuit you are testing to the building's earth ground.
