I have a HP server power supply that has a DC output of 12 volts, 75 amps at 900 watts off of a 110 AC input. How can this be modfied to increase the output voltage to 13.8? Attached are 2 pictures. 1 picture is of the contacts on the power supply that plug into a server. The second picture is off the same model power supply that has be modified to give the 13.8 volts output Im looking for. Can anyone help me identify what was done in picture 2 that may be what's increasing the voltage?
1 2
The resistor in picture 2 on the left side contacts is used to complete a connection to turn on the power supply with it being not plugged into a server. The 2 wide contacts are the negative and possitive contacts. In picture 2 there is something between the negative and possitive contacts and I need help identifying what it is and what it does so I can duplicate it on more power supplies.
Thanks in advance for help.
1 2
