power supply spec definition help needed
minkey01
Joined Jul 23, 2014
185
Hi.
I am trying to buy a dual output switching power supply. 5V and 24V.
http://www.jameco.com/Jameco/Products/ProdDS/323380.pdf
I understand all the specs except for one. Could someone explain to me what "INPUT AC Current typ." means? It is listed as .8A/115VAC. While the output DC says 2.2A and 1A. How can you have less amps in and more coming out?
Sorry for my stupid question. I am sure it is something easy and obvious.
Thanks!
Happy Holidays.
tindel
Joined Sep 16, 2012
936
Switching power supplies are all about power conversion becoming efficient. POWER OUT cannot be greater than POWER IN.
Watts = volts * amps
So it looks like you have about 100 Watts into the converter...
hvacpw
Joined Dec 24, 2014
A power supply is an electronic device that supplies electric energy to an electrical load. The primary function of a power supply is to convert one form of electrical energy to another and, as a result, power supplies are sometimes referred to as electric power converters. Some power supplies are discrete, stand-alone devices, whereas others are built into larger devices along with their loads. Examples of the latter include power supplies found in desktop computers and consumer electronics devices.
ScottWang
Joined Aug 23, 2012
7,400
The Power of AC part as:
Win = Vin * Iin = 115V * 0.8A = 92 Wac
Assuming eff(efficient) = 90%
Wout = Win * Eff = 92Wac * 90% = 82.8 Wac
The Power of DC part as:
Wdc = Wac * Pi = 82.8Wac * 1.414 = 117.1 Wdc max
The present Wout:
Wdc = (5V * 2.2A) + (24V *1A) = 11W + 24W =35 Wdc
So the rest power Pr = 117.1Wdc - 35Wdc = 82.1Wdc, the Wdc still have 82.1 Watts left.
