I am planning to build the PS shown attached. Anything I should change or be aware of?
Thanks.
Thanks.
Be aware that CR3 isn't connected to anythingI am planning to build the PS shown attached. Anything I should change or be aware of?
Thanks.
Assuming he already has the transformer, if he used the center tap as ground he'd end up with two ~4-6 volt outputs (positive and negative) -- the diagram shows the full output voltage as 12.6VAC, so if he were to use the center tap he'd only get 6.3VAC on either side.I just built a power supply for a school project, and it uses a very similar design, as far as the "positove supply" shows, I also used a transformer that has a center tap, what I was wondering was using the center tap to provide basically two power supplies, both 9V, but when used together, one would be "negative" in reference to the center tap, and the other positive, could that not be used, along with a pair of bridge rectifiers, to provide the desired goal of two power supplies?
