power supply ripple
ninjaman
Joined May 18, 2013
341
hello
I have to calculate the ripple voltage of four different capacitors in a power supply. the power supply is a transformer, bridge rectifier, load resistor and capacitor would go across the load.
I used multisim to simulate the circuit. I looked at the ripple which has a peak to peak value.
my question is, to get the mean dc value, what is the formula for this. is it the peak to peak value times 0.636?
I know 0.636 is the average. but im not sure if the peak to peak part is right?
any help would be great
thanks
simon
#12
Joined Nov 30, 2010
18,224
There is no such thing as the peak to peak value of DC. The peak to peak value of what? The ripple voltage? The transformer output voltage?
bountyhunter
Joined Sep 7, 2009
2,512
hello
No, I don't think there is a formula. You can do it graphically by drawing a horizontal line through the ripple such that the area above the line just fills in the "open" areas below the line.
#12
Joined Nov 30, 2010
18,224
I would guess that the average value of the DC voltage is the peak value of the DC voltage minus 1/2 of the peak to peak ripple voltage.
ErnieM
Joined Apr 24, 2011
8,377
What do you mean by "mean DC value"?
DC is a constant. A DC value is the mean. It is also the peak, the minimum, the maximum, and every other characteristic name you have.
Assuming a transformer-bridge-cap configuration a useful first approximation is a cap bank charges to the peak AC from the rectifier, minus the diode drops. Then each cycle (or half cycle) it discharges per:
V = I * T / C where I is the load current, T is the time between cycles, and C is the cap.
THE_RB
Joined Feb 11, 2008
5,438
That's my take on it too. :) Where the ripple on the DC line is typical (probably less than 20% of the DC value, ie 12v DC with say 1v or 2v ripple) it is symmetrical enough to give the DC value as half way between the ripple peaks and troughs.
34,464
No calculations needed. If you are simulating it in Multisim then just run the DC plus ripple through a low-frequency LP RC filter (say 1meg in series with 10uF to ground). That will give you the average DC voltage of the DC plus the ripple.
ninjaman
Joined May 18, 2013
341
this is the assignment that I have done so far. it includes the results, sort of. if any one could offer some advice or point out anything I have done wrong I would really appreciate it.
thanks
simon
Measurement and testing
Power supply analysis
The brief is to build a power supply and measure the voltage and current using various testing methods. The assignment hand-out contained the circuit schematic and instructions for construction and testing.
The circuit was simulated on multisim, components and values were chosen and laid out similar to the given schematic. Simulated test equipment was attached to the circuit before and after the bridge rectifier to show alternating current and variable direct current. After getting the calculated mean DC voltage and current through the load resistor, capacitors were added to get values of ripple.
The oscilloscope was used to show the voltage waveform and ripple voltage. Using the grapher function on the oscilloscope, the waveforms could be isolated and enlarged to get a more accurate measurement. These measurements showed the ripple peak to peak voltage. Four capacitance values were entered and measured to show varying amounts of ripple voltage.
In supply voltage was just under 17 volts and calculated by using the formula:
12 volts rms * 1.414 = 16.968 volts
As the voltage would pass through two diodes for each half wave, the diode voltage drop was taken as 0.6 volts per diode and 1.2 volts for each half wave. So subtracting this from the voltage peak gave:
17 vpk – 1.2 v = 15.8 vpk
The mean dc voltage was calculated as 15.8 volts * 0.636 = 10.0488 mean dc voltage
The mean dc current through the load was calculated using ohms law:
10volts = 0.00213mA = 2.13mA
4.7kΩ
Measured values
Capacitors
1uf
22uf
47uf
100uf
Mean DC volts
15.5
20.9
20.8
20.4
Oscilloscope AC
Ripple
14.25
1.8
0.72v
0.36
Mean DC current
The table above shows the values taken from the live circuit using an oscilloscope to measure the ripple voltage and a multi-meter to measure the dc voltage and current.
Calculated values of voltage with capacitors
Capacitor
Peak voltage
Min voltage
Ripple difference
1uf
16.0579
6.0784
9.9795
22uf
15.8369
14.8268
1.0101
47uf
15.7200
15.2349
0.485
100uf
15.6317
15.4025
0.229
The above table shows the calculated values of ripple voltage simulated on multi-sim. The difference between maximum and minimum ripple voltage with each capacitor is shown. As the capacitor gets larger the ripple voltage difference gets smaller.
Limitations of the test equipment
Capacitor values
Calculated voltage
Actual voltage
Percentage error
1uf
11.585
15.51
33
22uf
15.342
20.4
32.9
47uf
15.482
20.8
34
100uf
15.518
20.9
34.6
The table above shows the percentage error for the values calculated on multi-sim and actual values taken with an oscilloscope. The quality of the meter is a factor and circuit simulation software doesn’t take into account real world problems such as component tolerances and quality.
Capacitor value
Actual value
Simulated value
Percentage error
1uf
14.25
9.9795
42.8
22uf
1.8
1.0101
78
47uf
0.72
0.485
48.45
100uf
0.36
0.229
57
The table above shows the actual ripple voltage measured on a live circuit with a multi-meter and the simulated value from multi-sim. The percentage error shows some inaccuracy. There were some issues with capacitor quality during testing that may attribute to this.
The multi-meter used was set to voltage and measurements were taken across the positive and negative rails. There were some issues getting an accurate reading with the higher capacitor readings. Poor readings are possibly because of the quality of the meter.
The oscilloscope measured peak values of voltage, again across the positive and negative rails. The channels were set to a voltage division that allowed us to get the most accurate reading. The oscilloscope took some practice to use and get accurate results and proved more useful than the multi-meter.
The simulation software is acceptable for approximate values but not to be relied upon for usable results.
MikeML
5,444
Or get a real Analog Simulator (LTSpice) which does it all for you...
Note the peak to peak voltage (cursors), the Average and the RMS voltage values.
Notice that for this waveform, Average and RMS are different. LTSpice knows all this...
