Power supply requirements.
Discussion in 'Homework Help' started by billynuris, Feb 10, 2011.
  1. billynuris
    Feb 10, 2011
    Good day !
    I have a load of 24volts 35watts heater.
    What capacity of power supply I need.
    Is 24V 70w is okey? and is there any problem if I used
    5000 watts power supply.
    Can I Used also LED Power supply. 24V 100W.
    Thanks!
    Billy
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Doesn't matter what capacity (wattage) power supply you use, as long as it provides a reasonably constant 24V DC and can deliver at least the minimum requirement of 35W per heater.
    With 70W, you could notionally run two heaters in parallel - although right on the supply's rating limit. It's always good practice to have some greater capacity than what you need. Environmental effects, such as high ambient temperature combined with limited cooling airflow may require the user to de-rate the supply, for reasons of safety and reliability.
    billynuris likes this.
  3. billynuris
    Feb 10, 2011
    So. I can used this "12V DC 8.3A Power Supply For LED Drivers"
  4. billynuris
    Feb 10, 2011
    Thanks! cause I confuse To LED POWER SUPPLY.... to normal power supply...
