I have a power supply that is regulated, The voltage is fixed but can be changed if need be.
Here is the question:
The voltage at the output terminal is at 14.6 volts and will allow 15 amps to be drawn from it.
I want to use it as a power supply for a Ham Radio Transceiver. Not sure which one, any one.
I suppose 13.8 volt is the standard voltage, but is 14.6 still ok in your opinion?
To me I think it is ok. I feel 15.5 volts is asking for trouble and 16 volts even more so. I seem to remember "some" alternators on cars going up to about 14.5- 14.8 volts "DC" at the output terminals, for you perfectionists. Why my pickup Ford F-250 diesel, goes even higher just after starting. near 18 volts then drops. Not saying that is right, but Lets just say The Ford is what it is.
Ok back to the power supply, how do you feel about it, if you have proof with your answer even better, but I like opinions too. I just want to know how close am I to ruining the radio?
