Power supply problem
Discussion in 'General Electronics Chat' started by cat3rn, Mar 30, 2009.
  1. cat3rn
    Thread Starter Active Member
    Jun 3, 2008
    117
    I have (had) a pyramid power supply 35 amp and have used it on my hydrogen cell numerous times. One day the fuse blew. I replaced the fuse only to have it blow again. I have replaced the mosfets and still fuse blows. I am not sure why. Can someone help me out it repairing this power supply?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Do you have photos of the board (both sides)? What is the model number?
  3. cat3rn
    Jun 3, 2008
    117
    Model number is on the front panel.
  4. studiot
    Nov 9, 2007
    5,005
    515
    Is this the powerline fuse on the input or a fuse on the ouput?
    Is it the fuse shown at the left in your second photo (of the back).
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Main issues with that model seem to be the fan dying. Overall, Pyramid doesn't have the greatest reviews, their cost is the only saving factor.
    You are also running it at max capacity, which isn't good for power supplies. For a 35A load, you should get a 50A or larger power supply.
    Finally, which MOSFETs did you replace?!?? That might be a problem.
    Just the same, here's the schematic extracted out of the PDF:
  7. cat3rn
    Jun 3, 2008
    117
    powerline fuse
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    First questions:
    Is the "Protection" Light on?
    Is there any voltage/current displayed on the meters with load connected or disconnected?
    How long was it turned on before the fuse blew?
    What is the part number of the output transistors you replaced?
    Might want to check around the protection circuit, it is a [SIZE=-1] TYN410 SCR, which is only rated for 10A. Also check the zener that triggers it (overvoltage circuit).
    Also check Q1, the TIP41C on it's own heatsink on the board. Both it and the SCR have slight discoloration of the heatsink tab rough corners (maybe).
    If you can unmount the circuit board and get a good, clear picture of the bottom, that will give a lot of insight towards any overheating. Solder joints will be 'greyish' and the solder mask itself changes color with high heat.
    [/SIZE]Caps look good from what I can see, make sure they aren't leaky if you have the equipment.
  9. studiot
    Nov 9, 2007
    5,005
    515
    Personally I'd ask myself if the fuse keeps blowing is it because the crowbar circuit (SCR) keeps activating for some reason.
    Another possibility would be shorted turns on the transformer. Are the TX voltages correct?
  10. cat3rn
    Jun 3, 2008
    117
    I just tested the fan and it runs fine. I was only running the PS at 20 amps.
    Sorry not the mosfets but the Bridge Rectifiers were replaced.
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=GBPC3501-E4/51GI-ND
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    First: What was wrong with the bridge rectifier you replaced? If it failed short, there could be a whole slew of problems.
    Per Studiot's idea:
    Measure the resistance of the transformer primary WHILE IT IS NOT PLUGGED INTO THE WALL.
    Do the same for the secondary, the diodes should prevent an incorrect reading from other components.
    Make sure the Collector-Emitter is not a short for any of the power transistors.
  12. cat3rn
    Jun 3, 2008
    117
    I don't know what the voltages are supposed to be.
  13. eblc1388
    Nov 28, 2008
    1,542
    102
    Can't read the fan rating from the photos. But if it is a 12V fan, then no wonder it will go dead soon as voltage as high as 18V is powering it(peak rectified voltage on capacitor C8).
  14. cat3rn
    Jun 3, 2008
    117
    No lights are on.
    Answered
    I used it for about 3 weeks and had it on that time for about 30 min.
    Earlier answer link to digikey.
    How do I check these? I have a meter with the diode check on it. I get 513 with the position a and it counts up to 1.999 then changes to a 1 in the b position. Using this as a guide.http://www.allaboutcircuits.com/vol_3/chpt_3/2.html
    Attached
    I dont own an ESR meter. I am trying to make the Blue ESR from
    http://www.anatekcorp.com/blueesr.htm
  15. cat3rn
    Jun 3, 2008
    117
    They where inexpensive and it was suggested that they might be the problem and they were easy to replace so I did and didn't check them out.
    Duh (not plugged in lol) but will do that and post the numbers.
    OK
    Where is this located and what is it. Not a genius here but pretty smart.
  16. cat3rn
    Jun 3, 2008
    117
    Its a 24V Fan. Thanks I had to check it out.
  17. thatoneguy
    Feb 19, 2009
    6,357
    718
    Didn't see pic/attachment for bottom of circuit board.
    Look at the datasheet for the transistors. Often the case is the collector, one pin is emitter, the other is base on a TO-3.
    If the bridge rectifier you replaced tested good (4 good diodes), then the negative input isn't a concern.
    If it took 30 minutes for the fuse to blow, it isn't a short, but a "big leak". Did the power supply function correctly while the fuse was good? Did it have voltage/current oddities right before it blew? Did the Voltage adjust need to be changed from "normal position" recently? Anything "Smell hot"?
    I'll be back in a while....
    --ETA: For the "NOT PLUGGED INTO THE WALL" Part is for people who find this site via google and try doing the tests. Too many people like to sue these days.
  18. cat3rn
    Jun 3, 2008
    117
    Sorry forgot to attach it.
    I know about that. Too many paeople make a living suing.
    Also attached is a better pic of the circuit board front.
  19. studiot
    Nov 9, 2007
    5,005
    515
    You are trying to fault find in a highly inefficient way.
    Let's try a systematic approach.
    Does the fault occur with little or no load?
    If not the fault cannot be due to excessive load now (though may be originally).
    Measure the transformer voltages (not resistances).
    Are they as expected?
    Move on to the rectifier voltages.
    If possible disconnect the smoothing capacitors so you are only measuring the TX and then the rectifier voltages.
    Reconnect the caps & measure the voltages.
    If all is hunky-dory here then the fault is in the subsequent circuitry.
  20. cat3rn
    Jun 3, 2008
    117
    No load whatsoever.
    Cant measure voltages if I can get it to turn on. Nothing gets past the fuse which is connected to the switch.
