I think it is a good solution IF you think the in-rush current is the main problem you must cure. the proper solution will change based on the problems the designer wishes to solve. it is very much a decision made based on the final needs of a specfic circuits operation.So your sasying the idea of putting a 0.666 ohm resistor is a bad idea?
Thread starter | Similar threads | Forum | Replies | Date |
C | Power supply | General Electronics Chat | 5 | |
M | Inrush current on power supply | Power Electronics | 7 | |
R | Inrush current for 775 motor and power supply | Power Electronics | 6 | |
Pos/Neg Power Supply = Inrush Current & other things | Power Electronics | 2 | ||
Power supply inrush current modeling and limiting | Power Electronics | 8 |
