Power supply hum
Discussion in 'General Electronics Chat' started by andrew24, Jul 18, 2012.
  1. andrew24
    Thread Starter Active Member
    Aug 20, 2008
    76
    I have a problem with a power supply 50Hz hum. When i power my telephone with a switching adapter (it doesn't have protective earth, it's a cheap china product) i hear a 50Hz hum/noise.
    But when i power it with a lab power supply or power supply adapter which has a transformer and a diode bridge in it and etc (it's not switching type adapter), then the 50Hz hum disappears.
    Also, when i touch my telephone PCB's ground with my finger or oscilloscope probe, the 50Hz hum disappears too.
    What is happening here? is it something related with ground loops?
    How could i reduce it? (when using the cheap switching power adapter)
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Use earth connection dummy!
  3. andrew24
    Aug 20, 2008
    76
    But the lab power supply doesn't have earth connection too. Why using it everything is ok?
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    what makes u think tht?
  5. andrew24
    Aug 20, 2008
    76
    Because i don't hear any when using non switching type power supply.
    And my device isn't intended to be earthed.
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    OK...at frequency do u think switching type operates?
  7. DigitalReaper
    Member
    Aug 7, 2010
    70
    The switching supply could be unregulated, it's not unheard of in cheap chinese stuff.
  8. R!f@@
    Apr 2, 2009
    8,785
    771
    tht was not what I asked.
    but u can try replacing the capacitors
