Power supply Help
Discussion in 'The Projects Forum' started by StephenMG, Feb 7, 2008.
  1. StephenMG
    Feb 7, 2008
    10
    I hope someone can help. I have a power supply with the following output specs.
    Voltage: 30 VDC Current 1560 milliamps
    I wanted to alter the current to a maximum of 1.5 milliamps. How do I do this?
    I think If I solder a resister to one side of the power cord it will drop the current but leave the voltage the same, which is what I want. But I don't know what size resister to use to do this.
    Thanks,
    StephenMG
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For a current limiting resistor, use Ohm's law. R = E/I. That comes out to a nice round 20,000 ohms for 30V/.0015A.
  3. StephenMG
    Feb 7, 2008
    10
    Ok, of if I use a 20k ohm resister it will drop the current to 1.5 milliamps but leave the volts at 30 VDC right? Also, what watt resistor should I get. I don't want to over-heat the resister and burn it out.
    Yes, John I would solder the resistor to one side of the DC output cord.
    Thank you again everyone
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If the impedance of the power supply is near zero, and you connect a 20K Ohm resistor across the output terminals, you should still read 30V across the resistor, and 1.5mA will be flowing through the resistor.
    If you measure less than 30V at the output after connecting the resistor, I'd be very surprised.
    You figure power in Watts using Ohm's Law.
    P = E x I
    P = 30V x 0.0015A
    P = 0.045 Watts
    That's roughly 1/22 Watts.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    It will leave the voltage at 30V until you put a load on it. If you want a supply that will put out a constant 30V for any current less than 1.5mA, it gets way more difficult. Now, if you wanted, say, 25V at a maximum current of 1.5mA, that would be fairly easy.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    The 20k resistor will indeed draw 1.5mA, but it won't limit the current through any other device you connect across the 30V supply.
    What are you actually trying to do?
  7. StephenMG
    Feb 7, 2008
    10
    Hi Ron,
    My friend built a device and now needs a power supply for it. He needs the power supply to provide a constant 32 VDC at a maximum current of 1.5 milliamps.
    So, I have a 32 VDC power supply that puts out 1560 milliamps and I need to drop the maximum current to 1.5 milliamps.
    I figured that if I use 1-20k ohm, 1-300 ohm and 1-33 ohm resistor soldered to one side of the output cord that it would be very close to a maximum current draw of 1.5 milliamps.
    Is this correct? or am I all messed up
    Thank you guys for helping me so much,
    StephenMG
  8. Ron H
    Apr 14, 2005
    7,050
    657
    The device will only draw as much current as it needs. The current rating on a power supply is the maximum current it can supply.
  9. StephenMG
    Feb 7, 2008
    10
    Ok, that I understand but this device based on a given condition will begin drawing more current and he only wants it to draw a maximum of 1.5 milliamps.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Can he live with less than 32V? How about 30V?
    EDIT: Here's a circuit that puts out (according to simulation) about 31.9V with no load, and 31.3V at 1.5mA. the voltage starts to drop like a rock at 1.593mA, and is zero at 1.595mA. The current limit is dependent primarily on the value of R1, and to a lesser degree on R2.
