Power Supply help
Discussion in 'General Electronics Chat' started by sarahwalker, Jan 29, 2013.
  1. sarahwalker
    Jan 29, 2013
    I'm currently having trouble finding a high enough ac/dc power supply that can power a Fanatec racing wheel. The specs are:
    Input: 100-240V - 1.5A 50/60Hz
    Output: 24 == 2.5A
    Outer Diameter 5mm
    Inner Diameter 2mm
    Center pin positive.
    I don't know a whole lot about electronics but from searching for a close psu all I could find was this: http://vancouver.kijiji.ca/c-buy-an...C-DC-Power-Supply-w-8-Tips-W0QQAdIdZ194816363
    I need one from Canada/US and need advice as my town doesn't have anything close.
    Thank you!
  2. BReeves
    Member
    Nov 24, 2012
    412
    64
  3. sarahwalker
    Jan 29, 2013
    That is way cheaper than what I have seen, thank you! I know I have to change the end but it's alot better than what I saw.
  4. sarahwalker
    Jan 29, 2013
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Are you sure about the plug dimensions? That is a very unusual plug.
  6. mcgyvr
    Oct 15, 2009
    4,789
    975
    not really.. Probably 5mm and 2.1mm which is common.
    and MPJA rocks for cheap power supplies and other off the wall overstock stuff..funky motors w/geartrains,etc..
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    It might be 2.1mm or it might be 2.5mm (which would be more likely for 24V), but 2mm is rare. The OP would be better off to know before buying.
