power supply HELP
Discussion in 'General Electronics Chat' started by goofydad207, May 17, 2010.
  1. goofydad207
    May 17, 2010
    A little help please i am building a 10 meter linear amplifier that needs a 13.8 volt 80 amp input :D I also need to build a power supply to handle it so i feel it needs at least a 13.8 v 100amp power supply to operate it effectively!! Does any one have a link to plans or plans them selves that i can use. I have a old (vintage power supply (tube type)) for some hv ac output although i havenot checked the output of this unit the outputs come out of the unit as a tube type connectors 11 pin or 16 pin. It maybe a good start!
  2. kingdano
    Member
    Apr 14, 2010
    377
    19
    10 meter amplifier?
    what does that mean?
  3. retched
    Dec 5, 2009
    5,201
    313
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Get a truck or golf cart 12v battery, a 130 Ampere GM alternator, and a 2-1/2 HP electric motor. Spin the alternator using the electric motor and a V-belt drive. You'll need to spin the alternator at between 6,000 to 9,000 RPM to get decent power out of it while keeping the air pumping through it to keep it cool.
    Power the motor using 240V.
  5. kingdano
    Member
    Apr 14, 2010
    377
    19
    :eek:
    holy electronics maniac batman
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    If you're willing to throw a little money at the problem, see if you can parallel two of these.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If he's going to spend that much, might as well get a quality unit, like this one:
    http://parts.digikey.com/1/parts/1207868-pwr-sup-fnt-end-12v-1200w-100a-th120012.html
    I like Lambda supplies. Not cheap, but not likely to break, either.
    Datasheet: http://us.tdk-lambda.com/lp/ftp/Specs/th.pdf
    You can adjust the output voltage anywhere between 10.4v and 14v inclusive.
    1% regulation at 100A output is pretty darn good, I'd say. Power factor is .99, 88% efficiency at full load.
    Trying to build a supply like that at home would be a major engineering effort. You'd probably wind up spending 3x that much and the resulting supply would not be nearly as efficient or reliable.
